Changing ....
Old May 25, 2009 | 05:35 PM
redjagsport's Avatar
Default Changing ....
Rear brakes tommarow
is it as simple as just putting in the new brake pads
or do i need to get a brake sensor ?
Old May 26, 2009 | 08:54 AM
JagXV6's Avatar
You need a tool to retract the piston back into the caliper. Because the emergency brake is built in you need to rotate and push the piston to get it back in.
Old Jun 6, 2009 | 01:40 PM
what tool is that?
where can i find?
Old Jun 6, 2009 | 04:29 PM
Curmudgeon's Avatar
Snap-On, MAC, Matco, probably NAPA>
The one I have is a cube, with a 3/8" square drive in all sides, and various ears on the sides.
You put an extension and ratchet into the opposide square hole, press and rotate, WITH the bleeder screw open, as you never, as in ever, want to push old fluid back through an anti-lock system.
It gets real expensive, real fast.
NAPA SER 3163, Disc Brake Piston Tool.
http://www.dmauto.com/web/dmauto/Cat.../mfg/SER/3163/
$12.42US
Old Jun 6, 2009 | 04:32 PM
Curmudgeon's Avatar
Old Jun 7, 2009 | 02:51 AM
thanks man
Old Jun 7, 2009 | 09:03 AM
JagXV6's Avatar
Not to start an arugument but there is no issue with pushing the fluid back to the master cylinder. There is no problem with opening the bleeder either. I have never had a problem with just pushing the fluid back. You will also note that the instructions with the tool posted above make no mention of opening the bleeder. Note that you will want to bleed the whole system if you do open the bleeders.
1100me
Jul 24, 2023 06:10 PM
Bcrary3
Feb 21, 2023 04:29 AM
Scarecrow
Mar 28, 2016 03:17 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
