auto box repair
No its not right. You have oil leaking out of the transfer box via the splines of the drive flange. To cure it when re-assembling put sealant on the output shaft before fitting the flange and again on the shaft before fitting the large nut. There is a TSB covering this, cannot remember the number at the moment.
