control arm squeaking---venting
Old Feb 12, 2018 | 03:01 PM
Kyuss's Avatar
Default control arm squeaking---venting
Ok I am getting fed up. My rear right lower control arm started squeaking again.... I have replaced it twice in the last 3 years.. It is so damn frustrating that these parts don't last. wth!!!
Old Feb 21, 2018 | 06:13 PM
Bizmuth Helm's Avatar
Default Load suspension
Make sure that after all the bolts are in place, and you are about to tighten everything up that you somehow let the weight of the car back down on the suspension. These things don't have much give, and if you tighten it up while it's all jacked up, and the wheel is at the bottom of it's travel, when you set it down it wants to twist the guts out of the bushing. There is just enough give in the rubber to flex under normal driving conditions. That's my best guess anyhow, having replaced that part on mine right after I got it.
Old Feb 22, 2018 | 08:37 AM
Kyuss's Avatar
Thanks Bizmuth, AS luck would have it my replacement control arm arrives today and the squeaking went away yesterday... At least I have it if/when the squeaking returns.
Old Feb 25, 2018 | 10:11 AM
Jag4's Avatar
Hi Kyuss,
If not already, try lithium grease around the bushings. Worked for me.
Old Feb 26, 2018 | 09:32 AM
Kyuss's Avatar
Thank you Jag4! If/when it comes back I will try that
lewandt
Apr 7, 2013 04:42 PM
JTsmks
Nov 29, 2012 06:28 AM
plums
Nov 15, 2011 05:21 PM
Mafioso
May 10, 2010 08:35 AM
