Doomed transfer case?
This, from the jag-lovers board, doesn't sound too good! FJT, is this your experience?
Some comments on the 'Air Scoop' used to aid cooling of the TC. "These scoops are what the engineering world calls an '11th hour patch' added at the last minute to help mitigate a high failure rated part that became too late to fix the right way in the development process. The TC in the X-Type is woefully undersized and weak for a car of this weight and engine size (and why engine modifications on this car meant to produce more HP and torque will cause chronic failures elsewhere in the drivetrain). Jaguar engineering was already in field test, likely at the beta level when they discovered the TC would be a problem, so they tacked on this air scoop to help rather than reengineer correctly, but frankly, it is about the equivalent of using a wine cork to stop a leak in the dike. Engineering simply evaluated the cost of reengineering compared to a clugy fix, and compared that to the estimated number of field failures expected and concluded it was less expensive just to replace TCs under warranty for a certain number of units. Of course, now the car is old enough that many are off factory warranty, and MANY TCs are succumbing on the owner's dime. Because of the poor and late in the process design, these scoops sit too low on the under chassis and are contiually ripped off in deep snow and in encounters with other road obstructions. It is much less a matter of lazy mechanics forgetting to relpace it after oil changes. So, if you are going to replace yours, consider purchasing a 'few' of them as inevitably you'll lose it more than once if you drive regularly in deep snow or, god forbid, off road. I agree, I'd rather have the scoop in place than missing, however, failures of the TC are related to driving habits combined with climatic operating conditions and condition of the oil inside the case. In other words, if you drive this car very sensibly in a colder climate, with a fully filled TC and occasionally have to lock up the VC, you might never experience a TC failure with or without the scoop. However, if you're a leadfoot with a 3.0L and constant hard accelerations driving in the very hot climate of Phoenix with a half filled TC, even with the scoop, it's only a matter of short time and you will be replacing the TC. " ________ 1999 XJR |
RE: Doomed transfer case?
i dont get it. what is TC? sorry newbie question...
Transfer Case
________ 1999 XJR |
mostly fair comments.. but I doubt the TC cant take the power of the engine.
Engineering the shafts, bearing, gears etc... for a certain torque, and power is not new technology. From what I have heard the failures are mostly from bearing failures. This is probably due to all that you are talking about. - High heat, and oil issues. The real culprit is the "lifetime fill" If you changed the fluid annually, I believe the problem would be reduced to significantly lower levels. Car makers are not going to change.. not anytime soon. So your only defence is to be wise.... change your TC oil once in a while. This is a little contrary to my rants about doing engine oil changes too often. Trust me there is always middle ground available for the truth to lie... |
I've heard about this "scoop" before, would anybody happen to have a pic so I can see what I'd be looking for to see if mine's still there?
I am picking up one today.. ill post a pic next week..
Ya know Bo,..Now that I changed my TC lube out to Royal Purple and you did the Red Line product (both top shelf lubes)...I believe, unless I was planning on keeping the car for another90K to 100K miles, I will not be changing it out again...We put in better than factory lubes and probably filled it to the proper level as well..
really helps to cool it. some times they brake off or people just throw them out.. im selling one to bo tonight you will see his soon
ORIGINAL: RudyF6 I've heard about this "scoop" before, would anybody happen to have a pic so I can see what I'd be looking for to see if mine's still there? Regards: Oldengineer |
