Eastiest droopy headlight adjustment!
Adjusting headlights
Actually, ...repair suggestions/advice! Only 2nd time under a hood, ever! Replaced headlight! Major accomplishment! Saw a video from UK (I believe), were you could adjust w/o kit (using a screw) but am unable to locate again! Will keep looking for tutorial! Thanking you in advance for
your response! L
your response! L
The adjustment screws (if internals not deteriorated) are on the left and right where the hood latch(s) is/are. If you look down inside the holes, you'll see the adjustment screws.
https://www.jaguarforums.com/forum/x...-x-type-65910/
If the internals are toast, buy a repair kit off e-bay =
