engine codes!
HELP! ....losing hair / losing sleep /.......need to resolve issue SAP! Continuing problem from engine warning light coming on and retrieved codes /well established service shop with good reputation with X Series etc. {but I am getting nervous!) 2002 2.5 AUTO /AWD /Petrol 65,000 miles 3/8/2018/ CODES P0171 & P0174....Cruise control unavailable message... Replaced upper intake manifold upper air control valve seal.......codes cleared RAN WELL UNTIL 12/6/2018/ ENGINE WARNING LIGHT /CODE P0I71 Smoke test for leaks ....Replaced intake manifold tuning actuator seals and booster hose assembly 12/19/18 ...ENGINE WARNING LIGHT /CODE P0I71 & P0174 Suspected cause...lean condition one or more fuel injectors on each bank Performed Engine Decarbonizing and Fuel Injection Cleaning SERVICE Motorvac throttle body plenum and intake cleaning / Motorvac internal combustion chamber cleaning Codes removed and drove well for next couple of days ....Engine Warning light back on with occasional Amber Light for a few minutes Anyone have had similar problem and can suggest anything? / very appreciated.....Do I change mechanic? or just what the hell are they missing?........ |
Change shops or DIY.
For DIY get a cheap OBD tool and use live data to see fuel trims - read forum messages about how & those codes. Stop swapping parts at silly cost and find out what is actually wrong. |
Originally Posted by JagV8
(Post 2008802)
For DIY get a cheap OBD tool and use live data to see fuel trims - read forum messages about how & those codes. Stop swapping parts at silly cost and find out what is actually wrong. OBD TOOL PROVIDED CODES P0171 & P0174.... Mechanic hopefully has been looking "live data to see fuel trims" what should he be doing~ update last two days engine has stayed off!>>>>>>>>>>>? |
P0171 & P0174 are nearly always a vacuum leak. Just do a search here and read the conditions and results. There are too many threads to repost.
+1 above
A common cause of those codes has been the 1 in dia crankcase breather hose from the cambox nearest the radiator to the inlet manifold. It wears and splits on its underside out of sight |
Also check the brake booster check valve and check the accordian hose between the MAF sensor and the throttle body to make sure it isn't split or loose.
