False 'gearbox fault' and 'DPF full' alerts
Its a couple of years since I bought My x type estate, first registered 2010, one of the last ones to be made. 2.2 Diesel Estate
This is by no means scientific but it is my experience. Anyway I started getting plagued by 'gearbox fault' and 'DPF full' alerts. I changed the DPF for an aftermarket one but I was still getting 'DPF full' alerts. Eventually I had a problem where the car fired up but immediately died which turned out to be the EGR valve which was stuck open. So after stripping out the EGR and cleaning and refitting it, the 'gearbox fault' and 'DPF full' alerts stopped. At least for a few thousand miles until they started again. So I bought ODB readers to see if there was a fault showing up. I tried three ODB readers, the only one which would read my car was 'iCarsoft'. So every time 'gearbox fault' and 'DPF full' alerts came up I looked on the reader for a fault, and guess what ? every time it showed up as a minor EGR fault, but it wasn't serious enough to bring up the dreaded check engine light. So My conclusion is that the car cannot show 'minor EGR fault' so instead it chooses either the 'gearbox fault' or 'DPF full' alert. Eventually I blanked off the EGR and fitted an EGR emulator which I found on eBay. Since then i have done quite a few thousand miles with no 'gearbox fault' or 'DPF full' alerts. The EGR emulator makes the computer think the EGR is working perfectly whereas it is completely disabled, and takes half an hour to fit. |
Dpf full and gearbox fault
Thanks for your post on this, after you cleaned the Egr, did it take a while for the message to disappear?
And was your car stuck in 3rf gear due to the gearbox fault?? I cleaned my Egr valve based on your successive results but nothing has happened yet. Regards Pieter
Originally Posted by harryxtype
(Post 2045485)
Hi Pieter
Before Cleaning the EGR, the Gearbox fault message would disappear after every time i stopped the engine and restarted, and yes the gearbox did seem to get stuck in a gear, but the DPF message stayed on. But after cleaning out the EGR valve both messages disappeared for a while. So get yourself an ODB reader off eBay, then you can clear the faults immediately. (the one which worked for me was the iCarsoft which i bought off eBay) But after fitting the EGR emulator, also off eBay, all fault messages disappeared and I have not had a 'gearbox fault' or 'DPF full' message for a few thousand miles. |
#harryxtype thanks for the reply on my message. Kind regards here from South Africa!
#harryxtype thanks for the reply. I will order the part asap. I am considering to remove the Cat and Dpf with reprogramming together with blanking. It's just a real newsance with these things.
I really appreciate your feedback. Regards from South Africa P. Foley |
harryxtype which emulator you applied ? I looked in ebay but haven't found one. I blanker EGR (2.2. D 2007) but now I want to eliminate EML engine error.
It is an EGR emulator for Jaguar x type,
Ebay item no,172986248307 (on eBay.uk) If you just blank off the EGR, the computer will know about it and give you an error code. So you have to blank it off and either remap the car, or put in an emulator to make the computer think that the EGR is still working as normal. (the emulator is something you can do yourself) |
Dpf full and gearbox fault - don't replace it yet
https://cimg0.ibsrv.net/gimg/www.jag...c7be0bb1c3.jpg
https://cimg1.ibsrv.net/gimg/www.jag...8cde0f569a.jpg This stuff really works in loosening everything in there. https://cimg4.ibsrv.net/gimg/www.jag...05873d093a.jpg The yellow stuff is the oil (diesel). If your car is serviced at correct intervals and you do frequent highway driving and your DPF light came on with the red light, chances are that it's NOT your DPF. Firstly, the DPF catches soot and prevents it from entering the air which prevents pollution. The gearbox fault warning on the X-Type is the "go to" response, I even got it when my alternator broke, so don't worry about that. In my case, my DPF warning light came on with a red light, also, a 'Gearbox Fault' appeared. The following day I took out my DPF and inspected it. It was rather clean. I made a contraption which I attached it to, this allowed me to rest the DPF from the 'enter' side to a pot on the stove (don't do it while your wife is at home). I inserted water into the pot, let it boil and put the DPF on top. The steam then enters and loosens all the soot. But I realised that a lot of 'oil' was coming out, A LOT. I immediately thought that it was due to the the wrong oil in my car, or over-filling. I also used heavy-duty degreaser which really helped remove particals of soot, but mostly 'oil'. Long story short, it wasn't oil, it was DIESEL. The 2.2 X-Type strangely and in rare cases, looses the coding on its injectors? This might be due to frequently loosening battery poles or the wrong battery or a faulty battery I would suppose. This in turn caused the injectors to fire at the incorrect intervals, the un-burned diesel then went directly to my DPF and the pressure sensor indicated 'DPF full'. The technician at Jaguar reprogrammed my injectors to the ECU and the car was perfect again, he did this free off charge I might mention. These are the codes I encountered before it was resolved: P1000 P0611 P1700 Things I encountered in diagnosing this problem to look at:
I was going to ask about a false gearbox warning
300km into a 5000km trip, no traffic lights for the last 200kms and at a steady 100km/h, stopped to fill up with fuel, and then the dpf full light comes on and the gearbox goes into limp mode. 3rd gear only. Cleared the gearbox code with the iCarsoft scanner enough to get the gearbox to cooperate to get me back home. The engine management code of P1700 comes up and the TC module show P1719 code, but no actual faults within the transmission. My conclusion was that the transmission was signalled to go into limp mode because of a fault that the ECU detects. In this case a RED DPF full signal. After reading the previous posts, (Thank you, they are helpful) I have decided to ignore the transmission fault and fix the DPF full fault. But how can I clear the DPF warning? The warning comes on before the engine has started, obviously the ECU remembers the condition. I have cleaned the EGR and have replaced the air filter, but now what. The only code is the P242F code which is ash accumulation. (Plus the P1700 and the P1719 then the P1000 none of which I am assuming have anything to do with the problem.)
I have disconnected the exhaust in front of the DPF to relieve the pressure of the DPF, if it really is full, but this makes no difference. So, the real question, how do I reset the RED DPF full signal? What else should I look at? Frustrating as it is always in limp mode and thus unusable. Thanks |
