Fuel filler neck tube rubber
Hi folks, I have to pull the fuel tank on my 2004 x type due to fix a broken fuel pump retainer ring. I'm concerned that during the removal of the tank I may damage the rubber neck even after loosening the clamps. Does anyone know where I could get a replacement rubber tube as shown I diagram? I'm having trouble finding a replacement except for purchasing the whole metal tube apparently. Does anyone know what diameter the rubber hose is so maybe I can cut one from stock tubing? I'd like to have parts in hand before staring job to minimize down time.
Thanks, David https://cimg2.ibsrv.net/gimg/www.jag...e3b94490bf.jpg |
C2S17800 or C2S33826 depending on VIN
SNG Barratt sells it also. If you go to their website you can down load their parts catalog for the X-Type for free. It has all of the parts blowups and part numbers.
https://cimg4.ibsrv.net/gimg/www.jag...52d0c55235.jpg |
Thank you. This is what I was looking for. Forgive me if this seems trivial, but I am anew owner and the website wants to know part of the VIN. What part of the VIN do I check for compatibility for this part? My vin is SAJEB52D64XE10042
David Update. I think I use the E10042 section, so it would be the following? https://cimg3.ibsrv.net/gimg/www.jag...8e3b147853.jpg |
Correct
Thank you, all.
David |
