Gearbox fault?
Old 10-16-2014, 11:06 AM
Her jag's Avatar
Default Gearbox fault?
Help, please.
2002 xtype 3.0 AWD 138,000 mi
When put in D, Dash reads Gearbox fault, then, cruise not available.
yellow light on speedo and motor icon on tach.
Moves ok in Rev.
Feels like the brakes are on.
I will now look at our forum for answers/help.
Thank you.
Old 10-18-2014, 09:23 AM
Paulc732's Avatar
First thing you should do is have the fault codes read, any parts store will do this for you for free. Post the codes and we can point you in the right direction.
Second thing to check is tranny fluid level not so easy on our cars but can be done check out the posts on refilling transmission fluid.
Keep us posted on what you find.
Her jag (10-20-2014)
Old 10-20-2014, 09:02 AM
Her jag's Avatar
Thank you for your response.
Transmasters advised driving may increase damage.
Fluid is turning brown.
Feels like rear wheels are moving the car while front wheels are dragging.
I "may?" have a Masda trans.
Will try fluid & filter change.
Cannot see level ckeck plug due to a heavy metal guard bolted to trans.
My trans looks diff than photos I have seen so far.
Old 10-23-2014, 09:10 AM
Paulc732's Avatar
Here is the section of the Manual that describes how to drain/fill the transmission.
hope this helps
File Type: pdf
JaguarLover101
48
06-12-2023 10:28 AM
3lvis
10-01-2015 01:56 PM
dmatthewman
09-30-2015 10:10 AM
jjmiah217
09-28-2015 09:09 AM
Quick Reply: Gearbox fault?
