Headlight Clips
Anyone know where I can find the metal clips that hold the plastic housing around the headlight assembly?
Thanks |
Not available seperately from the complete headlamp assembly. You might try an automotive recycler. They may sell you some from some damaged headlamps that would otherwise be scrap. I would first look closely at yours. Usually the housing is broken where the ends of the clip go into the plastic housing and even if you got new ones you wouldn't be able to install them if your plastic is broken, they wont stay in.
Thanks, I actually screwed up when I was replacing one of my headlights it popped out and I miss placed it somewhere. So the plastic is still good
