Thermo |
11-18-2010 05:30 PM |
Jessy, no alternate that I am aware of. The only option that I could possibly think of is swapping in HID heads to see if the bulbs are going to last you longer. Granted, I have to ask this as it sounds like you are not doing this: When you put in the bulb, are you making sure not to touch the glass with your bare hands and if you do, do you make sure the bulb is spotless by simply rubbing the bulb with a clean towel? If you leave any sort of dirt/oil from your hands on the bulb, it will create a hot spot on the glass which will lead to quicker failure of the bulb. Also, you may want to check the voltage that your car runs at. If it is running a bit on the high side (up around 14.7 VDC or slightly higher), this can also lead to more rapid failure of bulbs. I know in my truck, I am still running on the factory bulbs after 13 years.
