How much driveshaft CV joint play?
Old Nov 24, 2019 | 06:23 PM
Jagboi64's Avatar
Default How much driveshaft CV joint play?
My 2007 X has the usual cold weather whine, and I have taken the driveshaft from a 2002 at the junkyard to evaluate it to see it I can replace the centre bearing and then swap driveshafts. I have tried greasing and it didn't quiet things down.
I'm looking at the CV joints at each end and there is noticeable play when I hold the driveshaft tube and turn the OD of the joint. Is this normal? Or is it an indication of a worn CV joint that should be replaced?
Old Nov 26, 2019 | 02:59 AM
DAVESPACEBAT's Avatar
Do you mean this part? Should be no measurable play.
https://www.ebay.co.uk/itm/Jaguar-X-...wAAOSwubdd1aHL
Old Nov 26, 2019 | 12:05 PM
Jagboi64's Avatar
That's the one, yes. Sounds like they need to be replaced then.
funracer
Jul 15, 2019 10:01 AM
XJ8JR
Apr 21, 2017 01:56 PM
RFXJ12
Feb 7, 2017 10:18 PM
bojangles
Sep 18, 2012 07:08 PM
iownme
Aug 5, 2011 06:38 AM
