Installing an OEM CD Changer
Old Feb 12, 2007 | 02:23 AM
IronCobra's Avatar
Default Installing an OEM CD Changer
Isa NON-Cd Changer equipt X-type pre-wired for the factory CD changer (power and fiber)?
Old Feb 12, 2007 | 12:28 PM
racerx82's Avatar
Default RE: Installing an OEM CD Changer
Check in the trunk, left side. You should see a wiring harness and the fiber optic cables taped together. If it's not there....
(my 05 is)
Old Feb 12, 2007 | 01:06 PM
IronCobra's Avatar
It is! Thanks!
Old Feb 12, 2007 | 09:36 PM
racerx82's Avatar
Sweet!
Old Feb 13, 2007 | 12:25 PM
IronCobra's Avatar
I just purchased a OEM CD changer from a 05 X-Type. When it gets here I will let you all know if it is plug and play.
Old Feb 13, 2007 | 01:20 PM
racerx82's Avatar
Should be....I don't see why it wouldn't work
Old Feb 13, 2007 | 03:48 PM
racerx82's Avatar
Yes, you should be able to pic one up in ebay...
Old Feb 16, 2007 | 07:50 PM
aquill1's Avatar
Hey Blkjak I think there is a button on the cd player (at least there is one on mine) that says am/fm cd and than a button that says cdc or something like that. When I press it on mine it changes it to cd.
Old Feb 17, 2007 | 02:21 AM
IronCobra's Avatar
I got the cd changer in... having a bit of a problem connecting it though. it appears that the conector in the car may not be the same as the connector on the changer iteslf. The harness in the car is a female adapter and the plug on the changer is the exact same female adapter, hence the problem.
Could someone with a factory changer please pull some of the panels back and take a few pictures of it for me? I need to see the wiring. I'm guessing that there is another harness that needs to be purchased that runs from the factory harness to the changer.
Please let me know if any of you can help.
Thanks!
Old Feb 17, 2007 | 01:58 PM
IronCobra's Avatar
That's awesomebrother! I don't have any messanger programs though.
Could you take a few pictures and e-mail them to: maxspeed101@yahoo.com?
I need pictures of the wiring behind the panel that the CD changer is in.
Thanks again!
Old Feb 19, 2007 | 04:38 PM
IronCobra's Avatar
Dude, you just saved me a ton of time!
I thought that there must be a patch fiber cable to connect from the factory harness to the changer. I ordered it last Friday and it should be arriving this week sometime. I will take pictures.
So far I've invested under $200 for this endevure. We'll see!
I plan on using some Alum sheet metal to make my own brakets to mount the unit. I will take pictures when I do the actual install.
Old Feb 22, 2007 | 09:02 PM
IronCobra's Avatar
How do I get into the menu to add the CDC button? I do not have the Navigation and there are several buttons that are not available on the non nav.
H20boy
Dec 24, 2024 03:23 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
texaspete
Sep 10, 2015 08:34 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
