jaguar x-type v6 intake resonator?
Old Aug 25, 2011 | 12:56 PM
websun's Avatar
Default jaguar x-type v6 intake resonator?
hello can somebody please tell me which is the intake resonator? http://images.thecarconnection.com/lrg/ ... 0627_l.jpg
Thank you
Old Aug 25, 2011 | 01:51 PM
Gold_04_X-Type's Avatar
Thank you
Here you go.
Attached Thumbnails jaguar x-type v6 intake resonator?-2008-jaguar-x-type-4-door-sedan-engine_100290627_l.jpg
Old Aug 28, 2011 | 02:33 PM
websun's Avatar
in EPC that's called air cleaner...
Old Aug 28, 2011 | 02:50 PM
Don't know what an EPC is, but the AIR CLEANER is the thing that says "Jaguar V6" on it.
Old Aug 29, 2011 | 02:52 AM
websun's Avatar
nope
Old Aug 30, 2011 | 11:34 AM
disguay's Avatar
Would removing the intake resonator give me a faster throttle response and make my car sound louder? Also, how difficult is it to remove? Thanks
Old Aug 30, 2011 | 01:39 PM
Thermo's Avatar
Veteran: Navy
disguay, as for adding power, it isn't going to do anything. If there is a gain, you are looking at under 1 hp. THe sole purpose of the resonator is to act as a surge volume for the incoming air to minimize intake air noise. You can remove the piece and then cover over the opening with some tape or other suitable plug.
ANy other "gains" would be not seen. As long as the piece is still functioning properly, I would not mess with it. The biggest gain that you are going to get is more intake noise as you open up the throttle.
Old Aug 30, 2011 | 08:07 PM
disguay's Avatar
Thermo, I was curious about the gain in noise, so what I did was took a video of what it sounded like with and without the resonator. After I plugged it, I found that there wasnt that much of a difference, but I decided it was so easy, that I would just try it. As soon as the video uploads, I will post a thread about it soon, more as just a bulletin to how pointless removing it is.
Old Aug 31, 2011 | 03:22 AM
websun's Avatar
Haven't gained much with the resonator however the coolant bypass mod helped a bit
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
ssshield
Sep 24, 2015 08:29 PM
explorer364
Sep 11, 2015 05:44 PM
