JTIS help
I've downloded and extracted the files but would like to know what to do next. I see setup.exe in several places and don't know which one to run or run first. Will this program work on a pc running XP? A walkthrough of how to set it up and run it would be appreciated. Thanks
RE: JTIS help
Raz, when I installed my JTIS, I did it off of the CD I bought. But, you should go to the SETUP.EXE under the main directory and that will be the one that you want to use for the overall program install. That is all I used when installing my disk.
Chris "Thermo" Coleman |
RE: JTIS help
Thanks Thermo. I found I had to go into dao\disk1 and install dao35 to get the program to run. After that I found it only goes up to 2003! Oh well, it was worth a shot to try it.
RE: JTIS help
If you copy all the files from the JTIS over to yoiiur PC after installing it you can use it without having to insert the disc.
