JTIS question
hi everybody,
it took some years but finally have purchased my first x-type. had already JTIS cd rom which states 2002-2004.5. my car states mfd date 08/05.august 2005 So my question: is there another jtis version for 2005-2006 Or isn't there much difference between 2002-2004 and 2005-2006? thanks |
I downloaded the CD from the links off this forum and when i try to unrar them I get "! C:\Documents and Settings\Administrator\Desktop\JCD-1.zip: The archive is either in unknown format or damaged"
Anybody know why? I too own a 2005 x-type. |
I think from 04 on they did not change anything on the X-Type.
Originally Posted by JagXType620
(Post 103482)
Anybody know why? I too own a 2005 x-type. You should be ok when you use a download manager as SDP downloader or similar (lot of fw available). The dl managers check the downloads for crc errors and will produce a runnable .zip file. At least I got mine working with no problems after that. With JTIS you should also notice that it uses an antique adobe reader which you have to install aswell. This will probably mess your newer acrobat reader's browser integrated components which you then have to install anew (the whole reader). |
