Lotus fan wanting an X-type - Advice?
Old Jul 10, 2009 | 09:10 AM
Cadillac's Avatar
Welcome ,
Visit Jaguar's official web site and hit X Type , you should see maintenance guide for X Type models
Old Jul 10, 2009 | 10:51 AM
The Chris X's Avatar
Greetings and welcome,
Do a quick search on the X type board and you will find a ton of good info on this very topic.
As always, a used car is going to have a lot of variables from prior ownership. My advice to you would be to get the newest and lowest mile example that you can afford.
Good luck on your search, I think you'll enjoy the X type.
P.S. - if you have more than 1 Lotus, do you have Loti?
Old Jul 10, 2009 | 10:57 AM
Thermo's Avatar
Veteran: Navy
Jam, prior maintenance is going to have a lot ot do with how good of a car you will get. Also, if the car has been involved in any accidents can play a factor too. As for long term reliability, you are going with the diesel and that motor will last you to well over 300K miles. So, enigne wise, you are good. The weak link with these cars is the transfer case. But, as long as you stick with the 04+ years, you will more than likely not have any issues. The real question is how hard you are day after day with the accelerator pedal. The more times you do the hard accelerations, the more likely you are to have transfer case issues. The rest of the car will hold up nicely and not give you any more problems than any other vehicle out there.
If you can afford an X-type, buy one. You won't be sorry.
Old Jul 12, 2009 | 06:58 AM
Thermo's Avatar
Veteran: Navy
Jam, no personal experiences thankfully. But, most of the guys that have had to get a new transfer case installed I seem to recall end up spending around $3000 USD. So, it isn't cheap. If you do the work yourself, then you are still spending around $1500 or so for a new transfer case (breaks the outer case normally and is beyond repair). The big trick with doing it yourself is that the right side of the transfer case has a special clip that if you don't install it correctly will rip an inner boot and you won't find that until you have been driving the car and you end up with a leak for the right front half shaft.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
mbergen
Oct 23, 2019 10:26 PM
cissdm
May 3, 2016 06:02 AM
jehart49
Sep 12, 2015 05:36 PM
