Manifold Gaskets Help!
I'm going to be changing the upper and lower gaskets. I found these online:
This set is only $26.00. Can I get two sets and do both upper and lower with these? Or are the lowers different? Felpro Intake Manifold Gasket - Auto Parts Warehouse I also found these. But they are like $16 each gasket. Anyone have a clue why they'd be that much? Upper - http://www.motorcarsltd.com/XR843536.html Lower - http://www.motorcarsltd.com/xr843533.html Any insight as to these or where I can purchase them all online at a good price would be appreciated. Thanks! |
Strafe, you want the parts from Motorcars LTD. Between the two parts, that will do both sections that are likely to cause you issues. If you are into the intake for the upper gaskets, it is just a little more work to do the lowers since you are in that far.
Hey Thermo, sent you a PM.
