Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   X-Type ( X400 ) (https://www.jaguarforums.com/forum/x-type-x400-14/)
-   -   Need to replace Alternator help! (https://www.jaguarforums.com/forum/x-type-x400-14/need-replace-alternator-help-10137/)
htkenan Jan 8, 2009 03:17 PM
This is my first time replacing my bad alternator in my X Type 2.5. Anybody got a installation guide which parts to remove step by step till I get to the alternator? Anybody done this yet?
mohrd Jan 8, 2009 06:22 PM
RE: Need to replace Alternator help!
Haven't done and wouldn't do it as I'm not skilled enough as I THINK you need to remove the A/C compressor as one of the first steps? Techs will be able to better advise. When I'm home I may have the steps on JTIS or Alldata and may PM you what Ihave if that will help.
ArmyJag Jan 8, 2009 06:50 PM
pm Christo he can give you the link to the free factory jag manuals for your car.
Real_Tech Jan 11, 2009 02:00 PM
Step1 discharge A/C, step 2 remove A/C compressor, easy after that. Are you sure it's the alternator? Common wiring issues with the wires running to the regulator, recommend double check. I've only installed one alternator for actual failure not related to collision damage. I've repaired wiring on another 100.
© 2026 MH Sub I, LLC dba Internet Brands
