Need some Help with Vacuum Lines
Hi all,
I just replaced a clutch in my X type jag. However I took so long to do it I forgot where a few Items go. Does anybody have a vacuum line diagram, I looked all though the manual but can’t seem to find one. 1 Is the vacuum line that T's from the intake manifold to the brake booster? https://cimg5.ibsrv.net/gimg/www.jag...5dcba747f4.jpg T That the vacuum line come off of. https://cimg7.ibsrv.net/gimg/www.jag...280097bfb6.jpg Vacuum Line |
Anybody have any thoughts on where this might go? I have googled it and used the searched this and other forums. It seems other X types do not have the T.
2004 X type UK model |
Down below the headlights just behind them is an ending point to connect that vacuum line onto. Right side from front looking at engine. There should be two ending points there.
Thanks for the help! I had taken pic of the engine compartment before starting the project and in the pics it looks as if the line does route towards the front but was unsure why a vacuum line would go up there.
What does the vacuum line supply vacuum too? I have looked around the head light area but can’t find anything that jumps out at me. I’m almost done with this project, car started fine and runs good at idle, clutch seems to be working and the trans shifts through the gears ok. Will road test it soon to get a real feel for the car.
