Oil Change????
Looking at doing this soon.
Any recommendation on the procedure or recommendations??? THANX |
RE: Oil Change????
get 7 qts of Oil and new oil filter from dealer..I use Castrol Syntec 5w30
RE: Oil Change????
Jack up front of car or use ramps..use proper safety
RE: Oil Change????
13MM wrench to remove drain plug..(Righty tighty, lefty loosey)
You may have to remove the TC cooling air scoop (one 10MM bolt) |
RE: Oil Change????
a band filter wrench to remove old filter..
RE: Oil Change????
Drain old oil and prefill new oil filter with fresh oil before installing.. smear a little oil film to filter rubber gasket too.
RE: Oil Change????
reinstall drain plug after it has dripped about 30 minutes..and lower car to level again
RE: Oil Change????
Add including what you put in filter, 6 qts and run engine for a few minutes and check oil level..
RE: Oil Change????
Top up oilto full mark on dip stick..Mine takes 6.8 qts all together.
RE: Oil Change????
I use mobile 1 synthetic with the mobile 1 synthetic oil filter. Best prices I have found were from Pep Boys in the USA, I am Canadian so every time I drive down to the states I buy 2 jugs and a filter. Also I noticed Sonic Delta car washes do a full synthetic mobile one oil change for about $65 which is about the same costs as parts but then if your pricing it out you are basically getting labour in for free. I have never done this as I just found out the price recently but maybe next time I will.
RE: Oil Change????
Isn't the x-type jaguar oil filter the same as a ford/motorcraft oil filter? If so does anyone know the part number?
RE: Oil Change????
RE: Oil Change????
Anyone using the oil filters with Teflon in them? Wonder if it helps any, for cars over 70K? or what about Teflon additives for synthetic?
RE: Oil Change????
Im confused. Is it okay to put synthetic oil in the V6 or no?
RE: Oil Change????
Yes it is okay..No problems, in fact you may see better mileage.
RE: Oil Change????
Thanks Dennis
Seeing that Jaguar does not approve synthetics in the V6had me a little scared especially since I had already put synthetic oil in mine |
RE: Oil Change????
It's a long story..but that was in the simplest terms.. a mistake on Jaguar's part..Had everything to do with the free olil changes they gave away at one time..So Sythetics are fine
RE: Oil Change????
The Motorcraft oil filter is an FL400S - I Believe.
Regards: Oldengineer |
RE: Oil Change????
The Motorcraft filter is the FL-420S. Chris "Thermo" Coleman
RE: Oil Change????
Wow lot of info here!!!
I was not really expecting this info with such a simple post. |
