power steering sqeaking
https://www.jaguarforums.com/...type...chnical-servic...
after all tires changed and a wheel alignment.. .an occasional squeaking starts after driving for 30 minutes plus anyone resolved such an issue using jaguar power steering additive?.....if so where to I purchase same? JAGUAR X SERIES AUTO 2.5 2002 / WHITE ROCK BC CANADA |
I'd replace the fluid using a turkey baster and couple quarts of Dexron III ATF. Suck as much fluid out of the reservoir as you can, then clean as much dirt as you can from bottom of reservoir. You'll be surprised how much debris is there, but PS fluid on most cars never gets serviced. Repeat process 2-3 times and you should see improvement.
4 Attachment(s)
TSBs are your friend. All these and more are uploaded here and are on Gus's site for your reading pleasure.
bob |
