Question about my stock Amplifier
I have a 2002 Jaguar X-type with premium sound system (or at least I think it is). I have replaced the door speakers and am very happy with them. I am now trying to set up two replacement speakers in the box under the rear deck. I have the speakers in place and wanted to use the existing wires to install an after market amplifier. The amplifier I am wanting to replace is the one inside the speaker box, that only has two output wires, which are red and black and eleven input wires. The input wires are 2-light blue, 2- white, 2- black, 2- green, 2- purple, and 1- dark blue. I have no idea what these wires are or why there would be so many of them to control one speaker. The second speaker in the box had no wires connected to it and no magnet or place to connect wires. I have searched the forum, and internet for some kind of diagram and could not find this particular set up. Everyone else that has an amplifier says it is located near the CD changer, I have no amp there, just the one for the sub. If setting up the amplifier this way proves to difficult, I would at least like to know which wires are the speaker wires so I can just hook them up un-amplified. Any help would be appreciated, and thank you for reading. P.S. The stock amplifier does not work.
Premium sound systems are 10 speaker, with an amplifier in the (LHD) driver's side trunk (boot). Non premium systems DO NOT have an amplifier ANYWHERE. Some pre 2004+ (the change) DO HAVE front door tweeters (again front only) & some do not with the standard system or was vice versa? Rear no front? Can't remember for sure.
Posting of installing non premium to premium with amp = https://www.jaguarforums.com/forum/x...ade-faq-64614/ |
REALLY? My car has 6 inch speakers and tweeters in all four doors and a stock box under the rear deck with one amplified sub woofer and a decoy that has no wiring, no place to put wires and no magnet. Have added a photo of the inside of the box to show that, YES, there are amps located in places other then the drivers side rear. I agree this is not the most common set up, which is why I can't find much information on it.
https://cimg3.ibsrv.net/gimg/www.jag...59579ac468.jpg |
They look like aftermarket. Originals are Alpine.
Amp is C2S38104, if you search by part number you can view a parts explosion of the audio system. Like at Virginia Jag, etc. Here's another link to a standard to better install. Note (no amp originally). http://forum.roadfly.com/threads/126...speaker-issues |
The speakers are aftermarket, as I mentioned in my original thread, I have already changed them. The amp is not aftermarket, which was the point of my second post.
So it only occurs in the first year model =
Originally Posted by Krisfx This is purely a FYI post really just in case you've ever wondered about the subwoofer that's mounted to the underside of the parcel shelf when you have the Premium Sound option. I wondered about it so decided to take it apart for a closer inspection. When you climb into the boot and look upwards, you will clearly spot 5 rather large gold bolts which undo easily. Just be careful to prop up the sub enclosure as if it drops, all of the weight will be taken by the wiring loom which could have consequences. Just unplug the loom and the enclosure can be pulled from the boot Undo the 15 to 20 screws (Cant remember off hand exactly how many but there was a LOT!) and you end up with this.. I had heard rumours but was a little shocked to discover they were true... one of the "subs" is indeed nothing more than a cone, designed I'm guessing, to use the air pressure from the powered sub to increase slightly the bass effect. My car is a 2001/02 model, so it has the Amplifier built into the enclosure rather than mounted to the side of the boot. It's the silver box seen here. Now for the fun bit.... The amplifier is actually pretty good and from what I can gather, it is the speakers which let this system down. So if, like me, you'd rather keep the interior looking standard rather than losing a lot of boot space to aftermarket amplifiers and subwoofer boxes and cutting up door cards to house larger speakers, you have options. Door speakers has been covered several times before I think so I won't go into any detail but if you want more bass without losing any space you will need two of these. Kicker Comp VT 6.5" But you have to make sure you buy the 2 Ohm versions as they would be wired in series so as to keep the load on the amp to the original 4 Ohms. The result should be a HUGE improvement over standard and in theory give similar bass to having a single 12" subwoofer in the boot. This has the advantage of being ported directly into the cabin though, which also increases the bass effect. I should point out that I haven't as yet done this mod myself but I will be going ahead with it as soon as possible. |
Continuation of the above pasted thread post from another member in a differend forum =
Originally Posted by jimmy I took a different tactic. I claim that little tin box is an absolute piece of crap amp, and it is not even worth its weight as a paperweight. I took mine apart as in the photos, then I cut the wire leading to the actual speaker. I extended both ends of the wire and made a small hole in the enclosure to pass both wires out of the box. I put it all back together. The non-working speaker looking thing is called a passive radiator (FYI) It acts to artificially increase the space of the enclosure. It moves out of phase with the actual driver, so it wont add bass at all. Then I mounted a decent 200 watt amp to the bottom of the enclosure, It is one that can run "booster style" that means speaker level input (not preamp input). I used the signal from the original amp to supply to the new amp, this way I did not need a seperate crossover. I connected the wire from the original drive to the output of the new amp. There is already a decent power wire run to the back of the car, it is good for 30 amps. The wire is dead from the factory, you will need to plug in a relay into the fuse box under the hood then the accessory wire will come alive! Is is one of several small black ones, go to any scrap yard and get one for a dollar. Or pay the dealer 90 bucks!!! At the yard, go to any same era ford and there will be several in every fuse box of every car. Now this is an easy way to get the early cars premium sound working better. I have not heard the later models premium sound so I cant say how it compares. There is one little trick that is needed, and that is the factory little crap amp has no typical "turn on" wire, and it will not work unless it thinks there is a speaker connected to it. Remember the speaker wire that came from the amp and is now connected to the high level inputs of the new amp? well it needs to have a resistor across it to simulate a speaker. I added a capacitor too, because it was not always turning on when I started the car. Originally Posted by PreJag OK. I did the 2? Kicker install last weekend and I have to agree with jimmy that the stock amp leaves a lot to be desired. Sub frequencies are more reinforced with the Kickers, however, if you're looking for big baddaboom, look to a trunk mounted box with separate amp. I'm going to give it a couple weeks to let the new subs break-in. After that I'll probably be looking at a small (~300w max) Class D mono amp that can be installed within the 30a rating of the stock power wiring that's already in the trunk. The Kicker install required reaming of the speaker mounting area with the trusty Dremel using a sanding drum to fit the speaker frames properly. Also, the plastic rims on the subs need to trimmed where they touch together in the center. Otherwise, the install is fairly straightforward. The other thing to consider is ripping out the whole thing & starting from scratch...like I did |
Jaguar Mechanic response to 2002 Jag owner's "where is amp"?
I am Randall. Very sorry for the delay there is an amp, kind of, it is not like a remote sole amp. the amp is internal to the rear sub woofer speaker. You replace the sub woofer to accomplish changing the amp. I have put the wiring diragram, description from the manual and link of loaction/repair click HERE to upload the link to repair info, description and diagrams follow Optimum acoustic detail is achieved through mounting the speakers high on each door panel, the standard sound system has four speakers. On the premium sound system there are: Four mid bass door speakers.Four door mounted tweeters.Enclosed sub-woofer with integral amplifier mounted beneath the rear parcel shelf. https://cimg9.ibsrv.net/gimg/www.jag...0115384cea.jpg |
Thank you very much! The wiring diagram is very helpful. Even though my wire colors don't match it is the same number of wires and I believe I can work with that. I had read the other post you have added but did not see this diagram! Thanks again for digging this up!
