Radio Problems
Old Apr 27, 2016 | 08:03 AM
avern1's Avatar
Default Radio Problems
My 2002 x-type has sound only on the passenger side. When you access MODE and adjust L/R balance adding to left you get no sound and the volume on the right side decreases.
Is the problem in the head unit or the control unit. I am hoping some of the radio experts will chime in and help sort out.
Old Apr 27, 2016 | 09:27 PM
hlgeorge's Avatar
Could be multiple things. I would first check the wiring connections behind the radio.
Old Apr 30, 2016 | 11:24 AM
Larry-Cleveland's Avatar
If it turns out to be the radio head unit I have a 2003 radio / CD unit that works great but the display is bad. You would need to swap them around. screws and it plugs in.
$25 free shipping
Old Apr 30, 2016 | 12:44 PM
motorcarman's Avatar
The loudspeakers are a KNOWN fault for the X-Type.
I have repaired the speakers if the wire to the voice coil becomes 'open-circuit' from the connector terminal.
Check the speaker continuity of each speaker before you condemn the radio head unit!!!!!
bob
Old Apr 30, 2016 | 01:43 PM
hlgeorge's Avatar
When I first got my X-Type the radio didn't work. Found that all speakers were bad. Replaced the speakers and all was good.
Old May 4, 2016 | 02:23 PM
Back in the "day" I would use a small 9 volt battery to test speakers and wiring. Put the (+) of the 9 volt battery to the (+) of the speaker wire. Put a wire on the (-) of the small 9 volt battery and use that wire to quickly tap on the (-) wire of the speaker. If all is good you will hear some static coming out of the speaker.
Old May 4, 2016 | 08:43 PM
I agree that just a 'flash' of the wire connection should produce a 'pop' or 'static' if the wire is dragged across the connector.
bob
Old May 5, 2016 | 01:49 PM
avern1's Avatar
I have been slammed with work while the sun is shining. I have a couple of rain days coming up and will check out everyones suggetsions and report back. The radio with cd player will it interfere with the 6 disc changer in the trunk?
Heliwilly
Jun 3, 2016 04:26 AM
seleroman
May 9, 2016 08:19 PM
mdavidjl
Apr 25, 2016 08:48 PM
Johnken
Apr 23, 2016 11:22 PM
agd
Apr 22, 2016 09:57 AM
