Replacing X-Type Headlamps
Is it as simple as popping in a new bulb? Or is there some aiming involved? The last time I aimed a headlight, it was back in the 80's and I didn't do a good job. Granted it was a 79 Ford Mustang. So I don't want to screw up my Jag. Even if it is a wagon.
[IMG]local://upfiles/5568/38C6051FBD244E5DA00A395CA4EBBF1E.jpg[/IMG] |
RE: Replacing X-Type Headlamps
Its a bumper off job and re-aligning after fitting
Oh well. I would take it back to the dealer, but I have a good friend who is the Head Service Manager at a Honda dealership. Since the car went out of MFG warranty, he's been reliable and cheaper than the local Jag dealer. |
What's a good replacement headlamp?
4 Attachment(s)
Attachment 187088Attachment 187089Attachment 187090Attachment 187091
Hye sabbadoo...........check out the X type FAQ quick link thread. This has all sorts of FAQ's there re headlights / bulbs etc as well as others. Good luck Jim |
Does the bulb just need repacement or the entire lens need to be replaced?
no no no. just the bulb.... Sabb,are you asking about changing the bulb or the whole plastic housing?
he said headlamp (bulb) not the housing
yes all you do it put the bulb in! takes a couple minutes. you have to pull the caps off the back of the lights, then theres a little metal tab you open up like a hinge, and then pull the bulb out. http://autolumination.com/headlights.htmhas the best prices. scroll down. x-typehigh beams and low beams are H1 55watt. |
don't replace the bulb.... get HID's!
