Right rear ABS sensor 05 X-Type
Just replaced the right rear sensor on my 05 X-Type. Not even 30 days and the abs light came on and the code shows right rear. Any ideas what could be wrong?
Welcome to the forum heldt4,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X-Type forum. This is the place to post technical questions about your model. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
Bad bearing, bad (new) sensor, bad wiring, etc.
Check out the reluctor ring - the toothed/corrugated ring around the drive shaft that the sensor senses. They can corrode and break causing your sort of problem.
actually I checked the reluctor ring before I installed the new sensor and there were no cracks. It is somewhat rusty, but nothing out of the ordinary
ABS
I installed a new sensor and it seems to be working fine. Now I am feeling the ABS engaging on dry pavement. No light on the dash. Any ideas? Could it be the ABS control module?
