Sound system "speaker" question...
About 8 months ago I had my dead front and rear right-side main speakers replaced at a local sound shop. Good job, reasonable price, no complaints.
So last week, the front left speaker(in lower door) quit. I took it to the same shop today for replacement. Now sounds great. BUT... Now the door won't open from the inside until the electric locks are set and reset a couple of times - and even then you've gotta pull on the handle too hard. MY QUESTION... Did the audio technician have to remove or loosen the interior door panel to change out the speaker? I need to know before I give the shop a call to discuss the issue. Thanks in advance for your insight! . |
Yes. They probably just put the handle back together wrong. Sounds kind of like what happened to me when I took my door panels off. I didn't pay enough attention to the passenger front door when I put the panel back on and I couldn't get the door open from the inside. Hopefully they didn't break anything though.
Yes they absolutely put something together wrong or broke a few pins and its now putting excess stress on your inside lever, mine finally snapped costing me $900 due to replacement parts and the fact that I could not get my door open from the inside OR the outside. They had to remove the entire door seal to get into my door to open it...took them two days.
Do you happen to know the size of the rear speaker in the back?
Originally Posted by wazrun
(Post 945526)
(Post 945526)
Yep just confirmed it. |
Problem solved!
I did nothing! Today, door works just fine! Go figure... :confused:
Wild....well good to hear! No pun intended...well maybe
Originally Posted by bracester
(Post 946339)
