sun roof 03 X type
My power sun roof stops just about 2 inches before it completely closes, you have to jog it to get it closed, it runs smooth but doesn't pop up in the pop up only mode but will open completely in auto. I think it must have a torque limiter that is being triggered. I have no idea how to trouble shoot it or what needs to be removed to access the components or if it's just a adjustment like the windows need when the battery is disconnected. If anybody can help with tech pubs,web sites or info It would be very appreciated. I checked the manual but no mention of the sun roof. Thanks in advance!!
PS I did pull down the control switches to check for loose connections, all seemed good and tight |
Welcome to the forum holiday,
I've moved your question from General Tech Help to X-Type forum as it's model specific. Members here with the same model will be able to help. Do you have access to JTIS? Graham |
1 Attachment(s)
Here's the JTIS Roof Panel Troubleshooting guide:
Attachment 90367 It cross references several other documents but should help get you started. Graham |
03 sun roof
got it fixed, hope it holds, simple instructions:icon_biggrin:
