Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   X-Type ( X400 ) (https://www.jaguarforums.com/forum/x-type-x400-14/)
-   -   transmission problem code P0706 (https://www.jaguarforums.com/forum/x-type-x400-14/transmission-problem-code-p0706-119362/)
dylonstomm Jun 7, 2014 02:06 AM
ok i bought this jaguar has about 130k miles on it a few months in to having it when the car warms up it wont go in to drive or 4 but when the car is cold it works fine shifts fine if u put it up to 3 it goes in to limp mode but then works in all gears with reduced power but if u shift it fast enough from 3 back to drive it wont go in to limp mode and works fine thought it was the rotary switch replaced it did nothing still gives me the same code dont have a hole lot of money so not trying to just throw parts at it does any one have a idea what is wrong
car5car Jun 7, 2014 02:09 PM
Search and find out what this come mean. Post results.
dylonstomm Jun 7, 2014 07:58 PM
the code means transmission range sensor /circuit
car5car Jun 7, 2014 10:02 PM
It is probably easy to replace.
DKurtti Jun 8, 2014 08:09 AM
If you've replaced rotary switch already it may be the shift cable out of adjustment. Could also be switches in the J-gate. I would look at the cable first.
© 2026 MH Sub I, LLC dba Internet Brands
