Trouble swapping out front shocks
So I bought a pair shocks and I've swapped them out before on Hondas and a few cavaliers so I naturally thought I would be able to tackle this job...but I noticed once i took the bottom bolt and the 3 top ones removed the drop link from the shock to the sway bar and lines that there wasn't enough play to slip the shock out of the brace. So I thought I'd remove this other link but it didn't help only I damaged the bushing:( I bought 2 new drop links but I don't know what the part is, it connects lower down...can someone tell me? And any advice how to finish
https://cimg4.ibsrv.net/gimg/www.jag...958088b790.jpg |
Shocks or struts?
front STRUTS = rear SHOCKS = |
Originally Posted by Dell Gailey
(Post 2044524)
Shocks or struts?
front STRUTS = https://youtu.be/BeZ1flDFJZ0 rear SHOCKS = https://youtu.be/STum4frYvB4 |
https://www.carid.com/2006-jaguar-x-...1⊂-model[Liter][]=3.0L
Sad day for me..struts won the battle the rotor is completely stuck and I've managed to damage sum bushings...call the local shop they $1300 ouch!! Can't win them all I guess
What went wrong?
After watching the video Dell posted; The only "dicey" things are: having a good coil spring compressor, and the drive-axle to hub nut be a real head-ache (if not sometimes impossible) to loosen without a good impact gun. Only one-side is screwed up right? |
this is the one i used ...your ride will be very smooth after install
https://imagizer.imageshack.com/v2/3...924/JizERd.jpg https://imagizer.imageshack.com/v2/3...922/KMQkqy.jpg https://imagizer.imageshack.com/v2/3...924/JizERd.jpg https://imagizer.imageshack.com/v2/1...923/eI1Ne6.jpg |
Originally Posted by dennis black
(Post 2045561)
all my parts were ordered from rock auto extremely cheap for oem parts
i followed the video ,it was fairly easy 1 hour per side....i did spray pb blaster around the hub and stuck a screw driver in the gap ,then 2 taps with a hammer it was off in the pic thats how far you have to compress the spring https://imagizer.imageshack.com/v2/3...922/KMQkqy.jpg if you can change a tire ,you can do this |
(Post 2046218)
AutoZone has this loaner tool ($ shown is your deposit, refunded or not charged upon return at store's descression).
https://www.autozone.com/videos/v/64...018/185513035/ https://m.autozone.com/loan-a-tools/...ing+compressor |
Adding on to Dell's post; Autozone also has this variation available for loan which I've had pretty good success with on other makes/models with MacPherson struts. My local Autozone 's tool loan program requires you to pay for the tool, then refunds it back when you return it. AZ's saved me $100's not having to buy a tool that I will rarely use or need again. Here in San Diego this one is $55.00.
https://cimg7.ibsrv.net/gimg/www.jag...2eeb020f0d.jpg |
Shocks
If you just replaced the shocks on their own it would have been easier , that's what I did.
You also don't need to drop the subframe. |
Hey...I didn't give up, I have the spring compressor I'm waiting on the new drip link....The problem was the rotor was rusted wouldn't come off but I got it off now I'm gonna try to finish it.
Originally Posted by Luke Farrell
(Post 2046508)
Originally Posted by Sleek N Subtle
(Post 2046565)
How did take yours off? I have to take my brakes both links...did you leave all that on and still took it off?
i tried going at the rotar too but it was seized to it with rust i presume. just remove the knuckle pinch bolt so you dont have to go near the wheel hub , half shaft, rotar , all of that area. ill try upload some picture of the manual for you |
