wheels
Old Jul 18, 2012 | 09:17 AM
Heather2812's Avatar
Red face wheels
Hi, a humming noise seems to be coming from my back left wheel, it's not to loud but something isn't right. thanks
Old Jul 18, 2012 | 12:35 PM
91stealthes's Avatar
Could be a bad bearing. Does it make a wooh wooh wooh sound and then quite off a bit the faster you go?
Old Jul 18, 2012 | 02:12 PM
Thermo's Avatar
Veteran: Navy
Heather, what I want you to try is to take the car out for a drive and listen for the hum to start. Once the hum is happening and traffic conditions allow, move the steering wheel side to side to move the car at a decent rate (yet under control) side to side. When you turn 1 way does the noise continue but when you go the other way, the noise stops. If this is the case, odds are you have a bad bearing. You may also find that in a little bit, you will get an ABS warning light to come on. The ABS sensor is right in that same area and if things get bad enough, it will cause the sensor to loose sight of the other half of the sensor.
Old Jul 19, 2012 | 01:46 AM
Hi. yes there is a wooh wooh sound but it seems to be the same at any speed,
Old Jul 19, 2012 | 06:54 AM
Hi, thanks for all your help, it is the bearing, it's getting fixed now.thanks again.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
scooternva
19
Oct 27, 2015 02:14 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
