X-Type 2,0 petrol, sneezing, sobs, claps, increased fuel consumption
I do not know English speech, translate text Google translator. Please understand and forgive))) Thank you
We have the following problemma. At idle, or when you turn on "Drive", can be heard sobbing in the air filter. Noticed that it pulls the valve of idling. I took a 4 valve disassembly (Used) they are about the same-behaved. If the cut-off valve, sobbing disappear. The machine has increased consumption of gasoline. Catalysts knocked removed. Installed spacers on oxygen sensors "dummy" replaced by: 1 oxygen sensor (lambda sensor) lower Flowmeter sensor Airflow temperature sensor candles (2 times) Intake manifold gasket (upper great planted on the lower ring sealant, no air leaks) all possible locations of air leaks eliminated. Replaced the fuel pump, the entire assembly cleaned and treated silicone coil zazhiganiya- (ceased to twitch with smooth acceleration) At the moment I'm most excited about the increase in fuel. track at a speed of 100-130 km. h. average consumption 11.5 liters in the city in 16-20 liters of light mode. Smelly toxic exhaust gas. Help solve the problem. Thank you |
help mi
