Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   X-Type ( X400 ) (https://www.jaguarforums.com/forum/x-type-x400-14/)
-   -   x-type error codes (https://www.jaguarforums.com/forum/x-type-x400-14/x-type-error-codes-24287/)
Rascal3103 Sep 8, 2009 12:55 PM
x-type error codes
Hi All,
My x-type management light came on. Took it to a local garage who I know well and they said the codes are P0037, P1582, P2503.
They reset it for me but it came back on tonight. What do these mean and what are we talking in terms of a fix and cost?
BuckMR2 Sep 8, 2009 02:13 PM
Originally Posted by Rascal3103 (Post 138411)
Hi All,
P0037 is a HO2 Sensor heater control circuit bank 1, downstream (1/2)
P1582 is caused by either
1) Inertia switch activated
2)Throttle Limp Home mode
3) Engine starts and stumbles
4) Engine fail to start
5)Engine stall
Code P2503 I believe is charging system voltage low
How to find the problem and why they are all on and if related maybe someone else will know
Good luck
Rascal3103 Sep 8, 2009 02:16 PM
Cheers for the help. The P1582, my car did not limp home, fail to start or anything like that so all I can think is the inertia issue, what that is I have no idea.
Anybody know the best place for the O2 sensor (downstream) 2001, 3.0s.
I guess I will need to remove the old one to get the part number?
MarkC Sep 8, 2009 08:37 PM
The inertia switch trips in the event of an accident and presumably stays tripped until it is manually reset (which requires removing the lower passenger-side kick panel to access the switch. When the inertia switch trips, power to the ignition and fuel pump is interrupted and a signal is provided to automatically unlock the doors.
If your car still runs, then the inertia switch did not trip; however, it is possible that you may have a loose wire or intermittent connection in the inertia switch signal to the ECM such that the ECM "thinks" the switch has tripped, which causes the ECM to start the "flight data recorder" and store a code P1582 which indicates that data has been recorded. I would think the data that was recorded should include exactly what event triggered the recording (i.e., inertia switch trip, engine stumble, engine stall, etc). Bottom line is the Jag dealer should be able to read the transient event recorder log and tell you what caused the trip as well as a bunch of other potentially useful (or maybe useless) information, like how fast you were going when the event occurred.
Before buying a new o2 sensor, I would recommend reading the codes again to see if the same three codes appear. I can't think of anything that could tie the P0037 and P1582 codes together. Also, the O2 heater circuit is pretty easy to troubleshoot. If you ultimately decide to buy a new sensor, shop around. Here's one link....http://oxygensensors.com/index.php?r...FRBM5Qod0SovLg Just fill in the requested model info.
I can't find the P2503 code in JTIS. Sorry.
poboyblues Sep 8, 2009 11:38 PM
P1582 is Flight Recorder code. Meaning the ECM has recorded the failure in real time. You may be able to access this with a generic type scanner that has the protocol to read flight recorder, but I haven't seen any that will. The dealer can read it. It says alot, and can lead a competent tech to a fix when used correctly.
© 2026 MH Sub I, LLC dba Internet Brands
