X type fumes
hi looking for some help! I had a new turbo fitted last week as the x type kept going into limp mode, since the car was returned I now have a strong smell of fumes from the air vents when switched on and also coming from the driver side of the vehicle- coming in through window when it is open can any one advise? It is running fine, no visible smoke from exhaust under the car . Thanks.Sz
Welcome to the forum Panther15,
I've deleted your duplicate post from General Tech Help. Members here with the same model will be able to help. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
My guess is that they may have forgot a gasket either between the turbo and exhaust pipe. Or they pinched it putting it together. It don't take a huge gap to smell fumes in our cars. The way I check is I take a punk( a smoldering stick we use for lighting fireworks) Start the car and use the punk and go all along the seams where the turbo is and down pipe for exhaust. if there is a leak you will see the smoke move away from the pipe and the tip of the punk burn red as if you were blowing on it.
Hope this helps. Good Luck, The Dr! |
I am lost...the X-Type had no turbo...can someone clarify?
Turbo Diesel not sold in the US
| All times are GMT -5. The time now is 06:14 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
