X-Type stuck in park and won't start
Old 06-25-2014, 06:05 PM
xtype86's Avatar
Default X-Type stuck in park and won't start
Hello everybody, I have a auto 2.5 xtype that just wont start. I've already replaced the starter and the battery. Replaced starter because it would make the clunk noise whenever I would try to start it . Now I get nothing at all when I start the car just a tick at fuse box. Also wont go out of park. Someone pls help car just ran fine up until now.
Old 06-25-2014, 07:00 PM
xtype86's Avatar
Help pleassse!!
Old 06-25-2014, 08:13 PM
Bud Tender's Avatar
How are the battery cable ends? The ground cable has been known to cause problems at the end away from the battery.
Old 06-26-2014, 12:00 AM
xtype86's Avatar
Full story got my baby about 7 months ago. She started to throw a battery symbol about 2 months ago. Looked under hood and the cable from terminal to fuse box was loose. Tighten the terminal bolt and all was well. Now 2days ago it did the same thing except this time it was the one from the starter? I felt a hard clunk every time I started it. Then 5 hours later it died without being able to go in neutral. Thats when I did everything I said in my opening statement. As far as tapping the starter. It turned a few times while I taped it.then the starter started to make a fast spinning noise. After that I turned the key and no more stater noise, nothing at all!! Nothing but a tick at the fuse box. Replaced starter no more fast spinning noise. Car trys to crank while tapping but try get the car started with key nothing at all but click at fuse box. Also still stuck in park
Old 06-28-2014, 02:14 AM
mikesmith2's Avatar
Could it be the switch on the gear shifter, try moving the shifter slightly when trying to start car.
Also you could remove starter from car and see if it spins when some one turns the key.
Check all electrical connections again
Old 06-30-2014, 09:41 AM
xtype86's Avatar
Sorry guys it took me so long to reply car has been in the shop and my tech said there is no power from the ecu to the starter but the car was running fine until I replaced the starter. And thanks to everyone who's trying to help I really appreciate it. What can cause that?
Old 06-30-2014, 09:47 AM
xtype86's Avatar
Also can someone tell me if tapping the starter can fry out my computer?
Old 06-30-2014, 08:59 PM
Bruce in North Dakota's Avatar
Location: That Rectangular Hole in the Consciousness of America
Could be the "cascading effect": one problem begets the next.
Did you use a jump from another vehicle, or a charger with a "Start Boost" in trying to start the car when the starter was acting flaky?
That could have muncho'd the computer.
Next on the list of cascading events will likely be the little flap covers on the vanity mirrors will quit staying open. THAT, of course, is DIRECTLY ATTRIBUTABLE to tapping on the starter!!!
Old 07-10-2014, 08:39 AM
xtype86's Avatar
Hey guys im bak with an update. After about 2 weeks of my tech going over every thing in my car, a burnt out wire blew out my diode. Replaced wire and diode and shes bak on the road.this was caused by bad posittive battery terminals. So my advice to all is to check your terminals and make sure everything is good.
gkubrak (05-20-2020)
Old 07-10-2014, 09:37 AM
Paulc732's Avatar
Glad to hear you have everything sorted and are back on the road.
Old 05-16-2020, 01:47 PM
Eric Johnson's Avatar
I'm going through a similar issue which wire and diode was it that needed to be replaced!
Old 05-17-2020, 11:31 AM
italcarnut's Avatar
Where is this diode and wire? I am going through the same thing.
Old 05-19-2020, 02:58 PM
Gcfuller's Avatar
Same here! Please elaborate on which wire and diode. I think I have the same issue!
Old 05-20-2020, 08:09 AM
TonyJ1977's Avatar
Usually that wire with a diode that sometimes burns out is the one that connects to the back of the alternator. That wire usually feeds the car with power. The wire will have what looks like a black molded box maybe 6-8” or so away from the alternator connector. You can pierce that wire before and after the black box and make sure you have power on both sides of it. If you do then good. If not then you can temporarily make a jumper to bypass it to see if that fixes your problem and if it does then remove jumper and replace the wire and diode
Old 05-21-2020, 08:52 PM
italcarnut's Avatar
Great! Thanks for the response.Where do you recommend I get the diode and is there a number for it or part number? I would be interested in replacing it this weekend.
ro13erto
04-27-2022 03:48 PM
Angrycanuck
08-04-2016 12:34 PM
luisg707
01-23-2014 11:45 AM
w1n9m4n
06-04-2012 02:50 PM
chokeu2
02-17-2011 09:37 AM
Quick Reply: X-Type stuck in park and won't start
