Oil Catch-tank
hello lovers of good and beautiful cars!
Has anyone installed an oil catch-tank? if yes, help me, i want to install too. please throw off the pictures, for a better understanding. Jaguar 2.0 diesel,180hp, 2016year, left-hand drive thanks in advance for your replies and help. |
Why do you want to install an oil catch-tank ? Surely better to sort the problem out at its source.
An oil catch can is used to filter and catch the excess oil before recirculation. Its other goal is to prevent oil mist or vapour from reaching the crankcase, which is known as blow-by. Blow-by is defined as the loss of compression as it leaks past the piston rings into the crankcase. Once the oil droplets have been caught, clean air can be passed back into the engine intake for optimised combustion.
source: https://natrad.com.au/info-advice/wh...catch-can-do/# I couldn't describe it better |
