XF (X260) 2015 onwards
2010 XF premium power window issues
Old 06-22-2017, 12:40 AM
kylepfisher's Avatar
Default 2010 XF premium power window issues
has anyone had problems with the auto up function?
it worked before now none of the auto up on any four of the windows will work. Windows operating normally and all switches click up but no auto function??
Old 06-24-2017, 12:16 PM
mleskovar's Avatar
WINDOW RESET
The windows need to be reset if the battery is disconnected, becomes discharged, or the power supply is interrupted.
Once the power supply is restored, reset the windows as follows:
  1. Close the window fully.
  2. Release the switch. Lift it to the close position and hold for 2 seconds.
  3. Release the switch.
  4. Repeat the lift and release procedure twice more.
  5. Test the window for correct manual and automatic switch operation. See ELECTRIC WINDOWS.
  6. Repeat the procedure on each window.
