blowing fans with no heat
I have a 2009 jaguar xf,....the problem is the engine fan blows constantly I've seen the over heating message several times but then it goes away....inside blower works but there is no hot air through vents....
Originally Posted by blunt
(Post 1989211)
1. If you are loosing coolant you have a crack at a heater core. 2. If you are not loosing coolant then your heater core is clogged. Either way let your mechanic to check the heater core. I doubt you can do it yourself, but there is no need to go to a dealer for 2009 car either. Find a reputable mechanic and buy a part from a junk yard. |
somebody also mentioned it may be the thermostat...but I will definitely have them look at the heater core they want 680.00 to replace thermostat seems pretty expensive for that fix...
Well, the part itself (the thermostat) costs around $100 and I believe you can actually replace it yourself (again, for the right suggestion post in the forum for your model year). And for the car that old there is no need to go to a dealership with their $200 hourly rates.
Find a good mechanic and stick with him/her. This is not a major repair. |
thank you sir I appreciate the knowledge you shared with me....
If it's telling you it's overheating you need to diagnose fast before you drive it more Do you have a good independent shop who knows these cars? Or a code reader and post all the codes up here |
pricing
I was told I needed a water pump and thermostat housing unit and was quoted 1350.00 is that a good price..
(Post 1991283)
