2010 Jaguar XF misfire 2,4,6,8
Old Feb 22, 2023 | 11:22 AM
slashay's Avatar
Default 2010 Jaguar XF misfire 2,4,6,8
I picked up my first Jaguar about a year ago . 2010 Jaguar XF 5.0 s/c. I have had to do a lot of things on the car including the timing chains twice. After I replaced the timing chain the second time it fixed a lot of issues including restricted performance and it runs much smoother . But once every 4-5 times I start it the car misfires on 2,4,6,8. Again it doesn’t happen every start up just randomly. I took it to my local dealership and they said the timing is off by 4 degrees and one of my VVT is failing. They said it could be a number of things.
Has anyone in these forums had a similar issue , I’m at a point where I need to fix the car or just sell it and take my losses.
Old Feb 22, 2023 | 11:36 AM
slashay's Avatar
I get an engine code for
Misfire on 2
misfire on 4
misfire on 6
Misfire on 8
Engine misfire on first 1000 revolutions
Intake valve control solenoid circuit range/performance bank 1
Old Feb 22, 2023 | 06:23 PM
POD XF's Avatar
I'd start by checking the harnesses for both the spark plugs and the injectors on that bank.
Old Feb 24, 2023 | 12:57 PM
clubairth1's Avatar
Community Influencer
Can you post the actual codes?
You mention the dealer said you have a failing VVT but you don't have a VVT code?
What code reader are you musing?
Can you explain why you needed to do the timing chains twice? I have never heard of that before?
With the timing being off 4 degree's are you sure things were assembled correctly? Sounds like it's a tooth off somewhere?
TEpton
XF (X260)
Apr 15, 2022 08:00 PM
Paxo
Mar 17, 2022 01:37 PM
aqura
Mar 14, 2022 08:47 PM
stivanquasaru
XF (X260)
Oct 7, 2020 04:41 AM
jahmezis45
Apr 29, 2018 07:24 AM
