2010 supercharged white smoke
Old Jan 13, 2016 | 01:37 PM
10 XF Premium's Avatar
Originally Posted by Kaeghl
One injector being stuck open can "flood" the other cylinders.
This is a very inaccurate description of what is going on but one injector can show misfires on multiple cylinders.
Not on direct injection engines. Injectors feed the cylinders directly, not into the intake runner.
But a stuck injector will wash the cylinder walls, get past the rings, and contaminate the oil. That causes bad things at every oiling point inside the engine. Very bad things.
Old Jan 13, 2016 | 01:44 PM
Kaeghl's Avatar
What about misfire from exhaust side. I had two injectors go out and they indeed set misfires codes on the entire bank.
Old Jan 13, 2016 | 03:19 PM
Raw fuel being pushed into the exhaust runners and pipes could/would cause detonation where it is not supossed to be. That could cause all sorts of knock sensor "signals" and those shock waves could interrupt the normal exhaust flows from other cylinders in the bank.
The ECU could interpret that in many ways, throwing confusing codes.
I don't know
Old Jan 13, 2016 | 04:35 PM
sparkenzap's Avatar
I ain't buying that! But, as you say strange things happen when the signals run amuck.
Old Jan 14, 2016 | 07:32 PM
Rdyoung's Avatar
Originally Posted by Badcatt
(Xf) Any help is appreciated- was driving got the restricted performance message pulled over then whitesmoke started coming from the rightside exhaust went to a nearby partstore had them run a scan got coil codes and a multiple misfire code its also gas burning raw has a horrible smell tank was full to limp bk home which was under 10miles smoke was blowing and gas went to 88miles off of 224
Enclosed is the technician report on my injector problem , I thought it might help you diagnose your problem.
File Type: pdf
Old Jan 14, 2016 | 08:55 PM
sparkenzap's Avatar
Hmmh. I wonder how 1 injector set the misfires for all on that bank? Maybe the fuel rail pressure was low?
caldercay
Jan 14, 2016 06:26 PM
Big Otter
Jan 10, 2016 12:17 AM
slownlo
Jan 7, 2016 02:13 PM
Mark in Maine
Jan 3, 2016 08:18 PM
tat2ist
Jan 3, 2016 03:50 PM
