2010 xf gas mileage issue
Old Mar 7, 2018 | 07:35 PM
akramii's Avatar
Default 2010 xf gas mileage issue
Hello, I noticed my xf 2010 base model yesterday and today my car did this.. it’s happened a couple times in the past. My gas mileage will change after I start my car up again after using it...
Ex: my gas miles when I start my car will say 200 after driving to school (20min drive, 6.5miles) my gas mileage will be at 186.... then when leaving school a couple hours later, when I turn my car on it’ll say 198.
Old Mar 8, 2018 | 08:29 PM
BritCars's Avatar
That's the miles left until empty tank? If so it's driven by how much fuel is in the tank. When you restart the car it prob reads the fuel level and calculates range. So a 10 mile difference is just a half gallon which is prob well within the tank fuel level measuring error
Old Mar 9, 2018 | 05:29 AM
Swimref's Avatar
It's not just based on fuel in the tank. The computer calculates the range based on current (if driving) or recent fuel consumption. If you hot-rod around it calculates a much shorter range than during highway cruising.
Old Mar 13, 2018 | 08:58 PM
BritCars's Avatar
Correct. It's estimated fuel consumption based on recent driving x fuel remaining in the tank
But there is no new driving history between turning off the engine and turning it back on again. So I would imagine it's just the volume reading in the tank fluctuating.
Old Mar 14, 2018 | 08:53 AM
Swimref's Avatar
Let me try again. The fuel sensor in the tank is a good deal more precise than suggested. The range estimate given is tied to the average mpg readings given. When driving these are largely (but not completely) computed on usage during the current "trip," which is to say since the ignition was turned on or in some cases the trip computer reset. After a shutdown period following a short "trip" the range will be computed based on a longer history. The OP mentions a 6 mile drive of 20 minutes, indicating some stop-and-go. During and immediately after this trip the range will be computed on the poorer gas mileage happening during this drive. Later when the ignition is again turned on the range is calculated from a larger and more representative sample size and is therefore more accurate.
1964Daimler
Sep 8, 2015 11:54 PM
75Gremlin
Sep 23, 2014 07:31 AM
ArtyH
May 5, 2014 04:47 PM
Apr 25, 2010 05:04 AM
billinohio
Dec 13, 2007 01:58 AM
