2010 XFR Help
I recently purchased a 2010 XFR Supercharged. I bought it from a friend and the engine was locked up. Found an engine. Wasn’t cheap. Replaced and now I’m getting a p0019 hard fault code. It also threw up p0026 today after a short test drive. Anyone have any advice? Ive changed the cam sensors and still threw the codes. Thanks
Welcome to the forums GMedXFR,
I've moved your question from General Tech Help to X250 forum. This is the place to post technical questions about your model. Here is the extract from the 2010 XFR Workshop Manual for the two DTC's you have found: https://cimg2.ibsrv.net/gimg/www.jag...c6f8c69886.jpg Modern Jaguars use extended diagnostic codes. You will need dealer level diagnostics (Jaguar SDD) or equivalent to read the extended P0026 but at least you know it is an intake valve control issue. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
