2011 Jaguar XF camshaft position sensor location
Old Dec 28, 2018 | 07:55 PM
Guadiano's Avatar
Default 2011 Jaguar XF camshaft position sensor location
Hi new member to the jaguar ownership. I live in Atlanta Georgia just Brought a 2011 Jaguar XF in september. I try to diy when possible on the small stuff. What brings me to the forum., well a problem with a camshaft position sensor on bank 1 sensor A. On initial start up if the car is cold the rpm rev for about 45 secs and if I drive off I get a check engine light and reduce performance light after 5 minutes the reduce performance clears and the check engine light goes away after about 50 miles. If I let the car warm up I don’t get a check engine light at all. Scanned and pulled camshaft sensor code. Where are the camshaft position sensors located.. does this sound like a failure of the sensor
Old Dec 28, 2018 | 10:37 PM
lotusespritse's Avatar
There's not going to be any discussion about problems that cause a check engine light until you read and post the codes. It's silly to think of troubleshooting any modern car without pulling the codes. Why?? Why would you do that?? Why??
The total cost to read the codes is about $0.00 at a parts store. Again, why??
How could you possibly be a DIY'er if you don't even think to pull the codes? What are able to DIY? Putting in gas? Washing the windshield? You always pull the codes!!
Old Dec 29, 2018 | 03:33 AM
Guadiano's Avatar
Thanks for the advice, initially code was P0340, now it is hard to crank and running rough with a code P0016
Old Dec 29, 2018 | 03:45 AM
Guadiano's Avatar
initial code was P0340 now it throwing p0016
Old Dec 29, 2018 | 08:10 AM
Guadiano's Avatar
Was able to crank vehicle as normal, car still ran rough idle but noticed instantly heavy smell of gas coming from exhaust, restricted performance didn’t return until I reached speed of 30mph. Clueless need help on this one
Old Jan 8, 2019 | 02:19 AM
Bigg Will's Avatar
If you have any version of the 5.0 V8, the 4 cam position sensors (2 on each head) are located on the upper timing cover, on the front of the engine, bank 1 is the left 4 cylinders when facing the car. Looks like you have an issue with the intake cam position sensor bank 1. If any cam position sensor fails, the engine goes into limp mode. It should be just a remove and replace fix. Hope this helps.
Old Jan 8, 2019 | 02:42 AM
OzXFR's Avatar
OP, get yourself a copy of the AJ133 Technical Training doc from my Dropbox here: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
Then go to page 62.
Old Jan 8, 2019 | 07:46 AM
Guadiano's Avatar
thank you , just wanted to verify location... had a bigger problem fuel injectors on Bank 2 dumping raw fuel... to the point it was coming out the exhaust pipe
Guadiano
Dec 29, 2018 03:18 PM
bigalan
Jul 29, 2012 10:45 AM
bforsik
Jul 26, 2012 05:59 PM
03Jag4.2Stype
US Western
Apr 4, 2012 08:05 AM
Jan 15, 2007 12:24 AM
