2011 XFR how wide can I go??
Hey Gents,
modifying my 2011 jaguar XFR. came to the issue of needing more grip in the rear. what are the biggest johnnies I can fit in a stock fender. without cutting or suspension adjustment (will consider rolling inner fender a touch) curious if any of you have been able to fit anything bigger than 10 (width of rim) in the rear with a 290 or 295 width of tire. any suggestion to get the most meat back there? please and thank you. |
Yes, quite a few people have fitted 295mm tyres on the rear. On the oem rims without spacers that works fine. With aftermarket wheels or spacers you might get slight rubbing
See here for details https://www.jaguarforums.com/forum/x...-tires-219116/ I stuck with 285 but got summer wheels with a bit more 'poke' |
