2013 XF Workshop Manual: Fuel System & Engine
Dear All,
I got misfiring problem (P301 & P1315) and I want to locate the sensors. Also I want to check fuel injector and already bought special tool to remove the fuel injectors. Unable to solve the problem for more than 2 weeks and not driving the car. Do you have 2013 XF 2.0 L petrol Workshop Manual to cover 1) Engine and 2) Fuel System This may be similar to 3.0 litre petrol engine. Any help Note: This is my first Jaguar and giving enough problem at 99000 Km. Had before VW passat (9 years) , Nissan X-trail (10 years) for longer period and never had problem like this. Thanks, Senti |
Jaguar stopped making the workshop manual in 2011, I think. You have to get all of the information online these days on Topix. https://topix.landrover.jlrext.com/t...cle/lookupForm
In a 2013 XF you will have the Ford EcoBoost 2.0 turbo engine, not the later (late 2016) JLR Ingenium 2.0 turbo.
And even then it will be the older generation EcoBoost which was replaced with a newer version in late 2014. So search the Interwebz for a 2013 2.0 EcoBoost workshop Manual and you might get lucky, this engine was used in a heap of cars including the Oz Ford Falcon of the time. |
2 Attachment(s)
Assuming this is for your car, it looks like you need to remove the inlet manifold then the fuel rail.
Thank you u102768 and very useful pdfs.
Thanks for your information OzXFR.
Thanks Harry F.
