2015 XF S Rear diff noise/leaking pinion seal replaced 2018
Old Mar 12, 2022 | 04:58 AM
x2008type's Avatar
Default 2015 XF S Rear diff noise/leaking pinion seal replaced 2018
My 2015 X250 XF 3.0D S had an advisory for a rear differential fluid leak on its first MoT in 2018 at 15,000 miles. A new seal was fitted by the Jaguar dealer in 2018 and I assumed the problem was fully resolved. However, I took the car in for a Jaguar dealer service today at 40,000 miles and was told there is a noise coming from the differential and that rear diff pinion seal is moist. The noise is very slight and I can only hear it from the passenger seat, it just sounds like the air conditioning fan is on at a very low setting speed. The car still drives 100% fine. When my wife turned off the engine yesterday, I heard a noise coming from the rear wheel so it sounds as though it is making a noise on the over run.
I've read lots of horror stories online about XF rear diffs failing and it costing a fortune to replace them. Can someone recommend the best course of action to take?
I've found a transmission/differential specialist not too far away and I was thinking they should be able change the diff oil and put a new seal on. However, if the diff is already making a noise is it already damaged to an extent that a diff oil change won't improve things?
Also, I've heard that changing the diff oil and seal involves rebalancing the diff and this is a tricky job and that the diff won't be as smooth afterwards. Am I best to take it to a transmission/diff specialist rather than the Jaguar main dealer? I can't imagine the Jaguar dealer has that much experience of changing diffs unlike the specialists that work on transmissions and diffs every day and the Jaguar dealer wants £132 just to look at the problem again!
Am I best to get the diff oil and seal changed at a specialist and hope that the noise is resolved by this. Which is the best type of diff oil to use and am I correct in saying 0.85 litres should be used?
In the very worst case scenario, if the diff fails in the future, I have seen a few second hand diffs on eBay for around £250 - how much would it cost to get a used diff fitted and is it possible to fit a used diff without losing the smoothness of power delivery associated with the XF? I've read online that it can cost several thousand pounds to replace the diff but as I say there are always quite a few used diffs on eBay and I can't imagine that the labour would be thousands of pounds at an independent garage.
Ideally, I'd like to keep this car for many years to come - aside from this diff issue, everything is 100% fine with it but I am worried that this rear diff issue will be a persistent pain.
Old Mar 14, 2022 | 06:22 PM
Welcome to the forums x2008type,
Both versions of your question were automatically locked for moderation. I've unlocked this one and deleted the other.
JensenHealey
XJ40 ( XJ81 )
Feb 18, 2020 11:31 PM
Flugwerks
Jan 17, 2019 05:45 AM
gthawk1
Jun 10, 2014 06:25 AM
