50K Service
Old Mar 2, 2018 | 06:25 AM
kiddhan625's Avatar
Default 50K Service
Hey Guys, I am bout to hit 50k miles on my 2012 XFR. Outside of the regular stuff (Oil Changes) are there any fluids and other services I should consider being performed on the car. Outside of mileage it is 6 years old as well.
Old Mar 2, 2018 | 08:11 AM
pab's Avatar
pab
Well, I'd say that also replacing the engine air and interior pollen filters would be a reasonable thing to also do. Might be worth flushing the cooling system and renewing the antifreeze, too.
How old are the brake pads?
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current: '15 XF (X250) Portfolio AWD 3.0
Past B: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past A: '05 X-Type 3.0/auto Jaguar Racing Green
Old Mar 2, 2018 | 09:33 PM
kiddhan625's Avatar
Thanks for the feedback. I do the filters every 6 months. Front and Rear brakes are brand new along with brake fluid flush.
Good call on the coolant. Thanks
Old Mar 11, 2018 | 08:34 AM
Bigg Will's Avatar
Drive shaft flex disc (Guibo) check, PS, Diff and Trans service, belts.
Old Mar 11, 2018 | 12:48 PM
bmcinsd's Avatar
At 75k my differential fluid was just replaced (very dirty).
Just ordered these parts for next service in a couple weeks:
tranny fluid kit
ZF trans sleeves
trans mount (cracked)
Guibo disc (cracked)
Well Bearing (driver"s rear ) - (noisy)
When I had the car up for exhaust work, I had most areas checked and the above required replacement or service.
Old Mar 11, 2018 | 02:38 PM
mghirsch's Avatar
Brake fluid
gavinw35
May 19, 2012 06:37 AM
rothwell
Nov 29, 2010 04:22 PM
ron44094
Mar 3, 2010 04:04 PM
colombo
May 20, 2009 12:17 AM
jjones91
Apr 22, 2009 10:43 AM
