Alignment question
Old Mar 9, 2021 | 05:56 PM
juan gram's Avatar
Default Alignment question
I have a 2013 jaguar xk std.with 50,000 miles and need front tires.One front tire is has uneven tread use,should I have an alignment done before or after new 🤔 tires are installed
Old Mar 10, 2021 | 06:11 AM
Fraser Mitchell's Avatar
Its usual to do the alignment after the tyre fitting. It could be that one of the lower wishbone trunnion bushes is starting to fail. It's usually the front one, and causes the inner side to wear down as the car goes along due to tow-out. Sometimes this doesn't show on an alignment rig as the car is standing still, so might be prudent to get all the trunnion bushes checked out. However, at 50k miles, I would not expect trunnion wear, to be honest, it's likely something else. Have you hit any bad pot-holes recently ?
By the way, if you have an XK, you've posted in the wrong forum for your car. This forum is for the XF saloons 2007-2014
Old Mar 10, 2021 | 06:40 AM
juan gram's Avatar
thanks for the information, don't have a history,as i have just purchased, you have been most helpful
Timeisrelative
Jan 29, 2020 04:02 PM
jagtoes
Oct 22, 2014 07:02 PM
jagxkrtoofast
Mar 7, 2010 04:03 PM
StrateLoss
Dec 29, 2009 03:48 PM
Oldengineer
Aug 6, 2009 10:34 PM
