Alignment question
Old Jan 22, 2012 | 09:17 PM
jagular's Avatar
After ensuring that tire pressures are correct consider swapping tires left to right. If the drift also changes then you have a bad tire or possibly a bent rim.
What brand of tire? Brand new tires f an inferior brand are frequently bad from new.
Old Jan 23, 2012 | 08:31 AM
Watchgeek's Avatar
You should be covered under original warranty..4 years, 50k...check your cars in service date..some in service dates were 2008 for the 2009 models.
Old Jan 23, 2012 | 09:37 AM
jagular's Avatar
Alignment won't be covered under warranty. That is routine service. Most "alignment " issues turn out to be tire or wheel issues.
Old Jan 23, 2012 | 09:47 AM
Brutal's Avatar
Originally Posted by watchgeek
you should be covered under original warranty..4 years, 50k...check your cars in service date..some in service dates were 2008 for the 2009 models.
no 12 months 12k miles whichever comes first. You could imagine how many FREE alignments we would be doing because some people just cant drive and are parked when they hit the curb
Call the dealer and ask if was aligned. I align all my preowned cars when i work on them. But like jagular said. Alignments do not fix a tire pull
Old Jan 23, 2012 | 12:27 PM
duke_dallas's Avatar
Your alignment will not be covered under warranty. It's considered a service adjustment only covered for 1yr/12.5k.
EDIT - Oops, didn't see Brutal's response.
Old Jan 24, 2012 | 07:03 PM
Jerry S's Avatar
If you just bought the used car from a dealer, I would take it in and complain about the pull to the right. The alignment on these cars can be ruined by just one pothole or a hard curb bump.
PMKimpton
Aug 3, 2019 08:22 PM
James007
Oct 3, 2015 03:29 PM
MonacoDK
Sep 16, 2015 07:51 PM
Don R
Sep 14, 2015 12:34 PM
James007
Sep 6, 2015 06:47 PM
