Battery not charging
Old Oct 19, 2024 | 02:59 PM
valuefresh's Avatar
Default Battery not charging
2013 Jaguar XF, AWD, 3L V6 SC
BATTERY NOT CHARGING message, but it was - because it didn't break down, as I drove the remaining 40-minutes of my trip. Then restarted strong - no problem.
It happened a couple more times over the next 3-4 weeks. After searching the forum, I decided to replace my (several years old) main battery. Notified the software that the battery had been replaced.
Ran fine for about (3) weeks, but the message popped up again. Same thing - was able to drive the remaining 30 minutes of my trip. Then it started strong - no problem. Do you know if the small (secondary) battery could trip this message too? Should I replace my secondary battery, or should I move on to my alternator? Or take it somewhere, where they can troubleshoot my electrical & ground wires?
Any advice would be appreciated, as to the appropriate troubleshooting steps.
Old Nov 2, 2024 | 06:24 AM
valuefresh's Avatar
After posting, found this which would be the next most logical step:
https://www.jaguarforums.com/forum/x...essage-280725/
Old Nov 2, 2024 | 05:20 PM
John Williams's Avatar
Put a voltmeter across the battery & take a reading with the engine off & with the engine running.
Old Nov 3, 2024 | 08:31 AM
valuefresh's Avatar
Thank you John!
Old May 27, 2025 | 06:46 AM
valuefresh's Avatar
Conclusion - my situation ended up being a loose battery terminal
PghJag
Nov 2, 2024 06:26 AM
sulthan_amk
Dec 12, 2022 10:09 PM
nathan1s
Dec 5, 2022 07:52 AM
Biff Baxter
Feb 19, 2022 11:39 AM
joey4420
Nov 8, 2014 08:41 AM
